CMD Help
dye4metal
when i go to run CMD it shows up the box, but i cant type in it. the box is also empty. i have windows xp pro with service pack 2
Sounds like you have the same color text and backround.
In the upper left corner, click on the DOS looking icon and choose Properties, then go to Colors and check / change the colors
