If you have a Cooler Master Wavemaster or CM Praetorian case, would you please post your temps? Post your specs., and if you have the Wavemaster, post whether or not you have the top fan installed. If you have "modded" your case at all, post that also. This thread might be helpful to current and future owners of the Wavemaster & Praetorian cases. People considering either case should also find this helpful. I am wondering how my temps are, and whether I should install the top fan, switch cases, etc....
System Specs. are in sig. The P4 3.0c is not OC'd at all. (yet
A LeadTek 5700LE is what I have installed right now, 6800GT not here yet.
These are the temperatures according to Asus Probe and I don't know how accurate it is.
STOCK Intel Fan & Heatsink Room Temperature was 71F
IDLE
CPU 37C / 98F
MB 28C / 82F
PLAYING UT2004 for about 5 minutes
CPU 41C / 105F
MB 26C / 78F
Again, I DO NOT have the top fan installed in my Wavemaster. With these temps would you install the top fan? And if you would install it, would you have it blowing air INTO the case or OUT OF the case? I would prefer to keep the Audio / USB / Firewire ports if I could. Thanks for any input you can give.
S@nDmAn
IDLE
CPU 37C / 98F
MB 28C / 82F
CPU 41C / 105F
MB 26C / 78F
S@nDmAn
