CM Stacker assistance!
Milamber
I have a CM Stacker 810 and I am keen to change the layout a little to make the setup neater for cabling.
Is there a way I can remove this tray:
If it's riveted, you may find that you need to employ a drill. If the rivets are hidden....Break out hammer and cutting torch.:cool:
correct, drilling the rivets out are your only option. I have the same stacker and I'm quite sure they are riveted.
Thanks guys :)
Decided to put the PSU back in the top from the bottom and leave it be.
