Cloning drive (fast response apreciated)
Corban227
quick question. want to start this before i sleep. if i clone a drive is that just basically making an exact copy of the drive onto another in case i ever need to clone it back right? i want to clone my 80 gig SSD onto my old 80 gig HDD. would i be able to do this using EASEUS todo backup tool? (it has an option to clone a disk. thanks for the help)
I used EASEUS Disk Copy to clone my 80GB HDD onto my new SSD. It does exactly what you say (and what the name implies) - clones a disk.
A clone has identicle data to the source disk. If the source disk is bootable the clone will be too. It's like a snapshot in time and better than backups because the only "restore" you have to do, is to tell your bios to boot from it.
very cool. thx for the info. Also one mroe question. if i ever need to restore by cloning back froim the HDD to the SSD, will trim be functional, and will the drive be aligned properly?
edit:
i went to clone and got this warning
inconsistent disk parameter may lead to boot failure. if failed to boot please enter bios setup and modify the heads to 60 and the sector numbers per track to 12. try again.
what does that mean? (i am able to contiune with the clone but will wait till i get a response just incase i could mess somtheing up
edit:
Which software gives you that error?
And its free! I just did a clone with it recently too. It works, not much else to say...
yea but what about that error?
Sounds like Easus doesn't like the format of your SSD
but if failed to boot please enter bios setup and modify the heads to 60 and the sector numbers per track to 12.
That doesn't mean it's going to do anything to your origional drive but the clone may not boot.
It's not gonna hurt anything to try and you're definately going to want to test your clone to see if it works.
Just try it and make sure the clone is aligned correctly so when you need it, it actually works.
