Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Thanks for the link Benny. I didn't realize that they made a 2600 with the Thoroughbred core. So its Thoroughbred vs. Barton (which I'll need to research) and the Barton has twice the cache. I guess my question is what is the diff between greater clock speed w/less cache vs. lower clock speed w/double the cache...
Well you can see by AMD's performance rating (2600+) that a 1.91ghz/333mhz front side bus 512kb L2 is equivalent in performance to a 2.08ghz/333fsb 256k.
And also equal to a 2.13ghz/266fsb 256k L2.
The extra cache on the 512kb L2 will have a slightly higher temps in comparison to the 256k thoroughbred. This is not really a big deal though.
