Clear CMOS ?
waseem
Hi
I have the 750i xfx and the mbo have a Onboard Clear CMOS whats that do ? \
try to find in google but :confused:
Resets all the saved settings for overclock/booting/etc.
Pretty much you don't have to touch it unless you're computer isn't booting properly.
Do you have the manual still? That's where I always look. If you don't, I'm sure it's available online.
um, disconnect the power cable, pull the cmos battery. no manual required.
all boards have cmos clear. some of the newer ones have a little button to press. most have a jumper, and a 3 pin array. by shorting 2 of the pins, or pressing the cmos clear button, all the settings in bios are reset to default. so you would have to reset time (sometimes) boot order, boot device, voltages, multipliers, onboard peripherals, gtl refs, etc, etc. many newer boards have a place in bios where yiou can save several sets of bios settings, and load them. so if you have to clear your cmos, you can just load one of the saved ones, and you wont have to set them all manually.
