Cant believe how hard it is to find anything on these forums without the search function.. I've been looking for guides and videos on tearing out WC loops for replacement/etc. Generally, do they recommend running vinegar through the rad then flush it out with distilled water, but keeping irritants away from blocks as to save the coatings?
Isint it generally not recommended to pass vinegar through your pump as it's bad for the guts? Then how do I actually clean it, just cycle through a gallon of distilled water?
Essentially I'm going to take everything apart, put temporary tubing on the pieces, flush them out with vinegar, rinse with distilled, hook everything into a loop, pump distilled through it and when it's clear enough dip the intake and output tubes into a container of distilled and let it run for an hour or so. Will this sufficiently clean my pump, which has been running the same, uncleaned/changed water for the past year?
Yes, No, Maybe so?
Yes, No, Maybe so?
