Cleaning off AS5
iSkylla
I just took off my HSF off my CPU and I want to clean off the Artic Silver. What do I use to clean it off? I have some Isopropyl, will that work? What material should I use, like take a Q-Tip and dip it in the Alchohol and brush it off with that? Thanks
I usually use q tips and isopropyl. I would watch out for any sort of fibers being left on the processor though.
both isopropyl and acetone (fingernail polish remover) are good suggestions, the key with isopropyl is to make sure it is a high purity
you can use a q-tip or any other lint-free material (i use Maxell CD Cleaners)
Search function is your best friend...
This question must have been asked a million times on this forum already... Well, not quite a million, but way up there.
Isopropanol will do wonders alone, but your going to need something to get the AS5 off of the processor, therefore, a Q-Tip. Afterwards, if the Q-Tip has done its job right, you'll want to grab a lint free cloth and finish the job off for a wonderful polish. Yay!
