Clean Your Damn Rig!
Discussion in 'HardForum Tech News' started by HardOCP News, Oct 19, 2011.
  1. rsaotome
    rsaotome Limp Gawd
    168
    Jul 28, 2005
    Just cleaned mine last night, it didn't look this bad, but probably could've, if the dust & cat hair didn't get spread perfectly over the entire case... :p
    Tip, get the Metro Vacuum ED500 DataVac, quite loud, but saves a ton of $$$ on dust removers. ^_^
  2. TodayILearned
    TodayILearned n00b
    4
    Oct 20, 2011
    What does the mess look localized to just that area? The motherboard looks pretty clean...
  3. mrpc9886
    mrpc9886 Limp Gawd
    404
    Feb 1, 2008
    I did it for about $75. Used three 140mm fans running at half speed to keep the noise way down. When gaming hard I can hear the 460 spin up but nothing else- a slight whir, but it's under 50dB threshold of my audio SPL meter.
    They run in a fan array, pull air through a 3M Filtrete HEPA filter, 14"w X 20"h, and push into the front of the case across the 4 hard drives. Then it vents out the back through the vent holes (not in a push pull, not necessary) and the PSU and GTX 460 SSC video card (28fps on Unigine Heaven 2.5, 1920x1080, 4x, shaders high, DX11).
    I switched to the this arrangement after I got the 460 with it's rear exhaust and got a 3.8Ghz OC on the Q8400; at the same time flipped my case upside down to put the PSU at the bottom and all the rear plugs at the top for easy access (Since the front panel isn't there anymore). Also had to pull out the DVD and card reader and stick'em on the top (was the bottom of the case) with packing tape.
    Yeah, it's ugly as hell, but frankly I don't ever LOOK at the damned thing, I'm too busy USING it and that requires me to look at the MONITORS.
    But it's been running for over 7 months now in this configuration on the same filter that is gradually turning gray with dust but there's not a speck of dust inside the case on any of the cooling vanes of the CPU cooler (Q8400 @ 3.8GHz).
    Positive case pressure for the win.
  4. Greene420
    Greene420 Gawd
    767
    Sep 29, 2011
    I have had some PC fixes for friends and such that had dust like that in the CPU heatsink/fan.
    In CLEAN houses too, you guys are being a little overdramatic on the unclean house claim....
    I mean, my ENTIRE HAND full of this crap, just from the heatsink alone... lol. And I fixed all their "shut down random" problems. Try to avoid this guys..... stuff that bad can end up costing you way more than a $5 can of air :D
  5. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    29,297
    Oct 29, 2000
    How do you expect the system to stay cool?
    A little upkeep is all it takes to stay on top of the dust. Filters help, but are not perfect., and even with filters, you need to remove and clean them on a regular basis or they won't be effective.
    Either way there is going to be regular maintenance.
  6. Comte
    Comte Gawd
    946
    Jan 2, 2001
  7. necrosis
    necrosis Gawd
    758
    Oct 21, 2004
    I usually end up going to a LAN party or just over to a friends house with my computer every month or two. My computer makes a stop at my air compressor on its way to the car every time.
  8. wiseoracle
    wiseoracle 2[H]4U
    2,305
    Aug 22, 2002
    You don't want to use a vacuum, because it creates static electricity. Taking it outside with compressed air is better.
  9. Monkey34
    Monkey34 [H]ardness Supreme
    5,088
    Apr 11, 2003
    My clothes dryer trap is better than that.;)
    Looks like another PC on the floor.
  10. adonn78
    adonn78 Limp Gawd
    413
    Apr 6, 2006
    All you got to do is dust your rig ever 2-4 months i use dist filters and only have to do it every 3-6 months. His system looks way newer than my own. Where does he live in a dusty basement?
  11. Greene420
    Greene420 Gawd
    767
    Sep 29, 2011
  12. Zarathustra[H]
    29,297
    Oct 29, 2000
    I always keep my rigs on the floor. That helps distance the noise from my ears, as well as leaves me more free precious desk space. I would never put a mid or full tower on a desk.
  13. Kromix
    Kromix Limp Gawd
    275
    Jun 24, 2011
    yuck! dust cakes, dust bunnies, and dust sauce all over that thing...
  14. soulpunisher
    soulpunisher Limp Gawd
    242
    Jul 25, 2007
  15. AthlonXP
    AthlonXP [H]ard as it Gets
    20,351
    Oct 14, 2001
    I clean mine once a month.
  16. kevin82287
    kevin82287 Limp Gawd
    162
    Jan 7, 2009
    Ban??
  17. TwistedAegis
    TwistedAegis [H]ardForum Junkie
    8,958
    Oct 7, 2009
    Forget the PC, whoever that dude is needs to clean / vacuum his house more, holy crap!
  18. beowulf7
    beowulf7 [H]ardForum Junkie
    10,431
    Jun 30, 2005
    Yuck! Gives new meaning to dust magnet. Not just dust bunnies but dust monsters. :eek:
  19. jonnejon
    jonnejon [H]Lite
    72
    May 24, 2011
    Man, this happens to me all the time, the only time I clean it is when I upgrade components.
  20. Xee
    Xee [H]ard|Gawd
    2,020
    Nov 18, 2004
    I'd post pics of my rig but I'd probably get banned. I just keep putting off cleaning it until I "have time" but that's stretched out for a long time now.
  21. Outamyhead
    Outamyhead [H]ardness Supreme
    4,258
    Jan 3, 2008
    Probably thought being water cooled, meant don't have to clean the dust out.
  22. babochee
    babochee Gawd
    598
    Aug 5, 2008
    ^^^^^^ This =)
  23. Sakom
    Sakom Limp Gawd
    182
    Nov 1, 2008
    I live in a f'in desert with cats and long haired dogs in my house and my systems never get that bad. I clean the filters in my rig weekly and spray the heatsinks on the wife's computer clean about every two weeks. Her system is actually passively cooled with those big ass heatsinks in my sig.
  24. Dr. Righteous
    Dr. Righteous 2[H]4U
    3,162
    Aug 1, 2007
    I worked for a business for 10 years that did walk in PC service.
    That is NOTHING compared to what I have seen.
    The worst was always smokers (because they were generally nasty).
    Those were the one their walked into the store smoking and ignoring the 5 or 6 No Smoking signs.
    Their PCs were usually covered with a nasty yellow film and the inside was caked with cigarette smoke dust and filth. Usually it stunk so bad they would immediately take it to the dock and blow it out with an air compressor. And then several attempts with Formula 409 to get the yellow scum off their Dell or Gateway. I have to hand it to those guys, they took a lot of pride in their work and they usually got them clean enough the owners didn't recognize them. This was all BEFORE they started troubleshooting the actual problem. :rolleyes:
  25. beowulf7
    10,431
    Jun 30, 2005
    I normally air spray my rig 1-2 times/yr. It doesn't get too dirty since I have the case elevated off the carpet (so not sucking in dust from carpet - I learned my lesson from years ago), don't smoke, don't have pets, etc., so pretty much an ideal environment, short of a vacuum. :cool: That said, dust still happens and I blow that crap out.
  26. schmuckley
    schmuckley [H]ard|Gawd
    1,236
    Oct 21, 2011
  27. Behold_4iamBoggins
    Behold_4iamBoggins n00b
    14
    Sep 25, 2011
    That is nothing. Where I used to work a customer brought in their pc with a DEAD mouse inside. hahaha!
  28. Basiq Flac
    Basiq Flac [H]Lite
    85
    Oct 8, 2009
    WONDER TWIN POWERS CATIVATE!
    Form of Dust!
    Shape of a Hairball!
  29. Bman123
    Bman123 [H]ardness Supreme
    4,725
    Dec 19, 2007
    I have never worked on a clean pc. I have done a lot of work lately on electronics and nothing has been cleaned. I've been thru a couple cans of air this year just doing repairs.
  30. PersonalJ
    PersonalJ [H]ard|Gawd
    1,795
    Oct 2, 2010
    This is nothing, I once found what I believe to be a dead lizard in my case.
  31. The Neo Zero
    The Neo Zero Gawd
    846
    Oct 9, 2010
    eww I blow out my system once a week.. that shit builds up esp if you have high air flow.
  32. Crazy Chuckster
    Crazy Chuckster 2[H]4U
    3,112
    Oct 6, 2001
    Worst I have ever had the pleasure of working on was a PC that was used in a company that made wooden house trusses and pre made walls. The entire socket was packed with saw dust under the cpu....
  33. BlackMoonWolf
    BlackMoonWolf n00b
    13
    Mar 2, 2011
    Confiscate it. NOW. He is banned from ever building again.
    BANISH HIM TO THE WASTES OF A MEDIOCRE MASS-PRODUCED PIECE OF JUNK.
