Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well I built mine myself, so I don't really have anything but the manual for the pump. Should I just syphon distilled water through or should I take all the connections off and clean each separately?
I have completely disassembled my loop and I decided to submerge most of the parts to clean then in distilled water. Strangely I have noticed that all the of tubes have a white-ish residue on the inside, that isn't coming out. What should I do? Should I buy new tubing, or try something to clean everything out?
My Swiftech tubing built up a bad whitish film after about 6 months. I disassembled the loop then took a piece of wire hanger and crimped it over a piece of rag which I soaked in alcohol and pulled it through the tubing, it worked wonders.
you don't think it could be mildew do you? I am using zerex coolant which I believe is just basically a form of anti-freeze (although it is redish). Should I add something else to prevent such buildup?
edit: coat hanger worked, now I am just sort of looking for the cause.
No, I doubt it's mildew, there'd be crud in the water/coolant and my coolant was clear as a bell. I have no clue what caused it, I wasn't happy though.
