maverick786us
- Aug 24, 2006
Do I need this utility CleanMyMacX for my M1 MacBook Pro 16?
Macs does get virus, malware and all the crap a PC gets.Thank you everyone, I will not use this utility. After buying my 16 Inch M1 MacBook Pro, I was watching plenty of YouTube videos to see the reviews and other tips and tricks on my MacBook and I was getting paranoid that in most of the videos containing review and comparison of MacBook's, the speaker talked about CleanMyMac utility (off topic) to promote that product.
Something that I like the most about MacOS, that it doesn't have virus, malware, spywares , so unlike windows, one doesn't need to install those utilities and do the cleaning once or twice a week.
It is generally not necessary to use a third-party cleaning utility like CleanMyMacX on a modern Mac like the M1 MacBook Pro. Apple has designed the operating system to manage system resources and remove unnecessary files automatically, so there is usually no need to use a separate utility to do this.Do I need this utility CleanMyMacX for my M1 MacBook Pro 16?
lol, yeah they do. we use cisco amp* on our macs.Something that I like the most about MacOS, that it doesn't have virus, malware, spywares , so unlike windows, one doesn't need to install those utilities and do the cleaning once or twice a week.
However, if you feel that your Mac is running slower than it should or if you want to free up some disk space, there are several things you can try before considering a third-party utility like CleanMyMacX:
If you have tried these steps and are still experiencing performance issues, it might be worth considering a third-party utility like CleanMyMacX. However, it is important to note that these types of utilities can sometimes cause more problems than they solve, so it is always a good idea to be cautious and do your research before using one.
- Remove any unused or unnecessary apps from your Mac. This can help free up disk space and improve performance.
- Empty the trash. When you delete a file, it is not actually removed from your Mac until you empty the trash.
- Manage your startup items. Go to System Preferences > Users & Groups > Login Items and remove any unnecessary items from the list.
- Use the built-in Disk Utility to repair permissions and verify the disk.
- Reset the NVRAM (Non-Volatile Random-Access Memory) and SMC (System Management Controller). These are hardware-level settings that can sometimes be reset to help improve performance.
