Dang this case is looking awesome. I'm contemplating one of the smaller ones for my next build as I'm struggling to find a decent case that allows me the radiator space i'd like without being as big as say, the 800D. The cube case presents an intriguing compromise, tho this one would be about 5 steps beyond overkill for me. Did you list the exact dimensions somewhere?
Many thanks! CL cases offer you everything an enthusiast wants, space and the ability to add on via the pedestal. This is a case that you will have for many years to come, pull the trigger!
I have seen some clear acrylic cases at Fry's electronics if you live in America that are smaller and designed for water cooling. And they are crystal clear.
No comparison!
A few things arrived today and think I have all of the fittings that I will need. I also received some fan extension cables, 20' of clear LRT tubing, 4 Aqua temp sensors ( 8 in total) and 2 more Aqua flow meters....I tried to find Aqua inline filters for complete overkill, but no luck.....
Only 3 more shipments to go! Hopefully I will be leak testing by Sunday!
Cheers
