Cisco ios 15.2
Discussion in 'Networking & Security' started by Hammer!, May 4, 2019.
  1. Hammer!
    Hammer! [H]Lite
    116
    Nov 25, 2011
    Hi, I purchased a WS-C4948E-S switch off ebay...does anyone have IOS 15.2 firmware for this unit? Thanks!
  2. ChRoNo16
    ChRoNo16 [H]ard|Gawd
    1,393
    Feb 3, 2011
    I believe you have to buy that from Cisco Support.
  3. Hammer!
    Hammer! [H]Lite
    116
    Nov 25, 2011
    Thanks...I’m not looking for technical support...just the firmware image...any other thoughts?
  4. FNtastic
    FNtastic [H]ard|Gawd
    1,324
    Jul 6, 2013
    If you contact Cisco and tell them what hardware you have, they can provide you a download link. If you aren't looking to purchase anything, they can provide you an update to the existing firmware version that includes all their most recent security updates and has the same capabilities as the license that exists on the device.
    Outside that, if you don't currently have the version you want, all them what it'll cost you to get it on there.
  5. Farva
    Farva [H]ard as it Gets
    35,098
    Feb 3, 2004
    I once received an old switch with no firmware on it. When I contacted Cisco, they said I would have to purchase a license for it, which was ~$100. I imagine that Hammer will have the same issue.
  6. Hammer!
    Hammer! [H]Lite
    116
    Nov 25, 2011
    That’s very helpful. Thank you all for the advice.
  7. Daedalus0101101
    Daedalus0101101 [H]Lite
    109
    Mar 31, 2015
    What Farva said is correct, to an extent. They might have once done that but now they havent supported gray market devices for quite some now. Being just a regular Cisco Customer ( not a vendor, employee, or otherwise), its actually stated that you are not allowed to re-sell their equipment if you outgrow, get done with, decide you want a different device,etc..... Since there is no way to really enforce people from going to Amazon, eBay, etc... and selling the equipment used, Cisco enforces it on their end by not providing official support and firmware updates although the Community forums can usually provide some good support. It is also against the EULA to provide other people firmware. So if I happened to have a 4948 Switch and am able to download firmware and you are not, I am not allowed to give you the firmware files. Maybe they just gave us a different set of warnings and such since we their Unified Communications system, but they said it also applies to their hardware.
