Easy fellas. I waited quite a while to make this post until someone from our team had actually heard from hito, but i guess I didnt get us entered as I assumed he would. Sirmonkey - the vote you linked it still open for a few hours.
I have submitted a support email to WCG and posted in the forums asking if an Admin can enter us. The challenge is percentage increase and allows late entrance so if we can still get entered by tomorrow it shouldnt effect the outcome.
If we dont get entered for the challenge, for those of you that I disappointed, please accept my apology. I appreciate all of the people who have stepped up to help, but no hard feelings if you decided to run f@h.
Either way I will still participate and I will keep track of our teams participation manually and post it here. It wont be on the official WCG stats page but that matters very little to me anyway. Thanks again.
Just go to the projects tab and press the "No New Tasks" button for the WCG project.
We are in. The race is on.
I'm excited!
Also, I see the CPU utilization in task manager looks like a sawtooth on all cores, varying from 30 - 100%. Is that normal?
Me too!
Now for the noob questions - how do I know that it's working right? I see 12 jobs running, which makes sense on an Intel hex-core. The clean water ones estimate 2:50:xx to complete, and the childhood cancer around 5 hours. Are those appropriate? Also, I see the CPU utilization in task manager looks like a sawtooth on all cores, varying from 30 - 100%. Is that normal?
Where's the best stats pages to look at, and how often do they update?
Got the following working on this for us, just a small contribution:
Q9450 - 3.5 Ghz
Athlon X2 5000+ - 2.6 Ghz
Phenom II X6 1090T - 4.0 GHz
sooo, 12 cores, pretty small considering we have SR-2's here now
the clean water ones take roughly 3-3.5 hours on my phenom II 940 @ 3.4ghz. but dont trust the times til you complete about 15-20 WU's. the program averages out your completion time the more WU's it does. the cpu usage may fluctuate periodically. i suggest in the settings to set under advanced/preferences/processor usage "While processor usage is less than 25%, set that to 0.
stats: http://boincstats.com/
just look up your name then on the right side click the magnifying glass.
stats update every 24 hours on WCG's site, but im not sure about on the boincstats page. also note WCG uses its own point system so your WCG points will not match what you see on boincstats since it uses the correct boinc point system..
I'll have to give that a try, because right now it seems to be horribly inefficient at using 12 "cores", averaging about 70% CPU utilization overall (even though 12 projects are running).the cpu usage may fluctuate periodically. i suggest in the settings to set under advanced/preferences/processor usage "While processor usage is less than 25%, set that to 0.
On an i7 if i have HT turned on i can compute 8 WUs simultaneously. Would it be fast to turn off HT and run 4 units twice as fast?
So I am wondering though
I'm crunching with my 3 hex cores!
Me too!
OK, I am BOINC'ing now. I'll switch an SR-2 over tomorrow, although I don't think SR-2s are the way to go with this since it does not take advantage of SMP for a single project at all. It all looks too linear for the way my farm is set up. Great for older hardware i suppose, but my farm is too optimized for F@H to be nearly as effective in this.
