Christmas lights
painball
Is it safe to add christmas lights to the inside of my case? I was just thinking about how cool it would be to string some small multicolored christmas lights around my window on the inside of the case. :cool:
Sure, you can even power them with dc voltage.
Might add a little heat to your case, but nothing to worry about.
I tryed this before on an old AT comp... Make sure you have more then 4 lights or you will burn out the bulbs and it can be connected to the power supply. ;)
Oh yea dont go over 8 light bulbs becuase it would be really dim.
yea, I would hook up 5 lights to the yellow wire, that's 12 volts so each light will get 2.4 volts.
Christmas tree lights want 2.5 volts, so 2.4 will be great.
What I really wanna do is use the smaller multicolored lights, not the huge bulbs. I guess I gotta see how much power they use. All I gotta do is look on the box for the recommended power usage and divide it into 12? Seems simple enough. :)
