Check over this build for me please
1_legged_sheep
1) What will you be doing with this PC?
Gaming, gaming, and then some more gaming.
$1000 including shipping
3) Where do you live?
Kansas
4) What exact parts do you need for that budget?
CPU, MB, Memory, Vid Card, Case, PS, Heatsink, HD, DVDRW, etc
5) If reusing any parts, what parts will you be reusing?
None
6) Will you be overclocking?
Am I breathing? (yes)
27" Samsung 2ms LED 1920x1080
Wednesday
9) What features do you need in a motherboard?
mATX, Z68 or P67 chipset
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, I'm a computer science student so I have MSDN
Okay soo someone made me an offer I couldn't refuse for the system in my sig so it's time to build a new one (again). I really want to use Thermaltake's Armor A30 case and go Micro this time instead of mini. Please check if I forgot anything obvious.
CPU: i5-2500k = Kinda a gimmie now a days.
MB: ASRock Z68 PRO3-M = This will be my 3rd MB from ASRock. The previous 2 were amazing, I'm kinda an ASRock fanboy now. I stay away from their cheap crap though.
Heatsink: Cooler Master GeminII S RR-CCH-PBU1-GP = I've used it before, great heasink and will clear the power supply by about 5mm lol!
Case: Thermaltake Armor A30 = It just looks cool to me and I've wanted to try a build with it for a while now.
Power Supply: SILVERSTONE Strider Plus ST50F-P 500W = 500w will be plenty big enough for this build and I can use the short cables with it for a cleaner build.
Power Supply Addon: Short Cables for the PS = Expensive for cables but I had some extra cash in the build.
Memory: Whatever DDR3-1600 2x4gb kit happens to be on sale for around $75 on Wednesday. I usually stick with Kingston, Gskill, or Corsair though.
HD: Good old Samsung Spinpoint F3 1TB = The default patter drive to go to.
DVD: Whatever SATA DVDRW is on sale for around $20 on Wednesday
Vid Card: EVGA GTX 560 NON-TI = Overclocks easily to stock 560-TI levels. If I catch a good 560-TI or 6950 deal for around $200 I may opt for that instead.
Anything I missed? Anything on that parts list that sucks I should know about?
I would not go with that AsRock mobo since it only has a one year warranty. If you want to stick to AsRock, go for a P67 mobo instead since those are covered under Asrock's one extra warranty year promotion until June 30th. Otherwise, go for a Asus or MSI Z68 or P67 mobo.
PSU wise, I would not go with that PSU since it's a little overpriced for the quality you get. In fact once you factor in shipping, that Silverstone is only $3 cheaper than this superior quality and larger XFX PSU:
$93 - XFX P1-650X-CAH9 650W Modular PSU
