check out my new build
Beigelman
its with estimated prices in SHEKELS (1shekel =0.26737 Dollar)
CPU: Core i5 2500K 3.3Ghz, s1155, 6MB, GPU Core, Tray‎
http://ark.intel.com/products/52210/Intel-Core-i5-2500K-Processor-(6M-Cache-3_30-GHz)
900.0 EBAY
CPU Cooler: Scythe Mine 2 CPU Cooler
http://www.scythe-eu.com/en/products/cpu-cooler/mine-2.html
195 KSP
MotherBoard: Z68X-UD3P-B3 s1155 Core i3/i5/i7, Intel Z68, DDR3 2133, 2xPCI-E
http://www.gigabyte.com/products/product-page.aspx?pid=3850#sp
840 KSP
Memory: G.SKILL "SNIPER" 8192MB (4096MBX2) DDR3 1600 CL9 1.25
http://www.gskill.com/products.php?index=389
250.0 EBAY
ScreenCard: GIGABYTE - nVidia GTX560 Ti OC 1GB GDDR5 DX11 2xDVI Mini HDMI PCI-E
http://www.gigabyte.us/products/product-page.aspx?pid=3707#ov
1100 KSP
DiskDrive: DVD±RW GH24NS x24 Black SATA (Oem)‎
http://www.lg.com/il/it-products/optical-storage/LG-dvd-writer-GH24LS50.jsp
130 KSP
Case: Core 3000 Mid-Tower Atx Black Case (No PSU) ‎
http://www.fractal-design.com/?view=product&prod=60
355 KSP
Power Supply: GS 600W Active PFC 14cm Fan‎
http://www.corsair.com/power-supply-units/gaming-series-power-supply-units/gs600w.html
470 KSP
4220 shekels
i'm gonna order it, its ok?
(for gaming, serials and a little progremming and photoshop and autocad)
The RAM seems a little overpriced, since you can find comparable DDR3-1600 kits (at 1.5V - no real reason to pay extra for 1.25V) for around 30 USD, but I'm sure you're limited on your store selection.
Any chance you can find an Antec ECO or High Current Gamer, or perhaps a Corsair TX650 V2? That GS seems overpriced as well.
I know it is hard to compare pricing outside the US, but those are the two things I would look at.
Outamyhead - i currently using WD 1 T HD and it is good for me. also, hard drive is the smallest of my problems.
what i really would like to know is my cpu cooler would fit in that case(?)
Forceman - actually my store selection is not so limited as you think (also we all have the biggest store in the world name Ebay).
the efficiency of the memory of the memory is more importent to me the the price, because the cost of that spec is lower then i prepared for and i still got some money.
you still offer me to find other memory sticks?
the Corsair TX650 V2 is actually cost more then the GS 600W i chose.
i could go for the NEO ECO 620C. its cheaper. do you think its better?
You will not notice any difference between ddr3 1333, 1600, or 2133... So if ddr3 is cheaper, save your money and get it instead.
Nothing wrong with your choice, just offering up that you might be able to find cheaper 1.5V memory. As for the power supply, I'm not sure about the GS line from Corsair - someone else can probably give a better answer on the quality, but $115 is pretty expensive for a 600W PSU in the US (but prices in other areas obviously vary).
According to the measurements I have found, you'll have about an inch or a little less once the side panel is on, so you should be golden.
The Neo Eco 620C is a better choice than the GX 600W due to its higher quality and significantly larger +12 amperage rating. i.e the 620C has 48A on the +12V rail whereas the GS 600W only has 40A on the +12V.
ok. i'm taking the Neo Eco 620. i will think what to do with the memory..
do you i think i should replace the cpu cooler? ine inch its a litle tighty dont you think?
An inch is plenty of room. All it needs to do is close, as long as it's not physically touching the side panel you're fine. Therefore, even 1mm would be fine.
excelent :) thanks!
say Skillz, why is your cpu so powerful? couldant you be satisfied with i5 2500k?
do you recommend on buying some or all of the components from ebay?
I've only bought computer parts once from eBay and it was listed in new condition. I personally wouldn't purchase any computer part from eBay not in new condition.
