Purpose is to order tubing and a ball valve for draining on a 1/2" loop. I will probably get poly barb T's later on or elsewhere. Also I did a search but couldn't find a quick answer as to if brass would be safe in a loop with copper? I am assuming it is, but can never be too safe. the tubing will fit onto the barb end of the brass hose fitting and the thread will screw into the ball valve. I will probably add a small section of open hose to the end of the ball valve so it can flow better into a bucket or what have you. Also some of this stuff you have to buy in bulk like the brass hose fitting barb, do you think it would be cheaper to get it and a ball valve at home depot or something in a single package? I doubt it would be much cheaper even if it's possible, but I'm always open to suggestions or better ideas none the less.
Item#46055K21
Polypropylene Ball Valve with Assembly Nut 1/2" NPT Female Connection
Item#5346K25
Brass Hose Fitting Barb X Male Pipe for 1/2" Hose Id, 1/2" Pipe, Packs of 10
Item#5415K11
Worm-Drive Hose Clamp W/Zinc-Pltd Stl Screw 7/16" To 25/32" Clamp Id Range, 1/2" Band Width,
Packs of 10
Item#5233K43
Masterkleer General Purpose Clear PVC Tubing 7/16" Id, 9/16" Od, 1/16" Wall Thickness
Thank you for the assistance.
Item#46055K21
Item#5346K25
Item#5415K11
Packs of 10
Item#5233K43
