About to order, appreciate any inputs.
Computer will be used for office work, watching movies on the 30", and Photoshop, no gaming. I don't upgrade often, my last built was from circa 2000 that I used for 5 years. I also need the setup to be as silen as possible.
Q6600
Asus P5K wifi
Enermax 82+ 425watt power
HD, my existing HD, which is an ide 200GB. I will figue this one out to optimize for Photoshop.
4GB Ram, GSkill 2GB x2. What speed should I get? PC6400 $80 or PC8000 $100
Graphic card (has to be fanless). Which one, I found Nvidia 8500 or ATI 3470?
For the video cards, I need 2 of them (prefer PCIe x16). I need the first card to drive a 19" and a 30" (most cards have at least one dual link these days), and the second card drives a high res 9+ megapixel display via DVI.
I like the PC to be quiet, so I though to add a 3rd party heat sink. Noctua with the 120mm fan or Termaltake 120, they both look kinda the same.
Thanks all.
Q6600
Asus P5K wifi
Thanks all.
