Well if you would like to get a good bit more points per day my advice would be to get the GPU client going on that 8800 and put your dual core to work on the SMP client. Not sure how many points the 8800 is getting right now, but I would imagine that combo would get you to at least 4000 ppd. Someone else can correct me for sure. And yes, that PS3 is good for about 900 points per day I believe. It is pretty reliable too but quite the space heater.
If you do not want to do the SMP client, which by the way would get you quite a bit more points per day, you could at least put the uniprocessor that you are currently running on your machine twice and allow advanced work units.
Also started folding..
e8400, 4850 for now.
WIth the e8400 at stock and 4850 at 700/1175, which will produce more ppd?
Another 4850 coming for CF.
Alright I am going to hijack this thread to get some help for me.
Tried to start folding a few days ago on my 8600 GT, but cant get even a single WU completed. Anyways thats besides the point.
I got 2gigs of ram, and a Core2Duo 6300 (1.86ghz). I wanna crank PPD. SMP client? Wtf? Read all the (very informative) stickys in here, but I need to know what client(s) I should install. Will they also work along side the GPU client (if it would work for me?)
