Hi All: I just built a computer for a friend of mine. I paid for it out of my pocket because he helps us out with handyman type of things all of the time! Anyway....He plays some light type of games & surfs the net etc. I wanted to get an inexpensive video card other then the onboard 6150SE.
He uses a Samsung 17" LCD (1280x1024) & only has a VGA out. I was thinking about this MSI 4350 512MB @ 25.99 AR $10.00 rebate (if I'm lucky enough to get the rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127411
Also..I should note I'm using a fairly cheap Allied 285 PSU that came with the MSI barebones set up. I don't want to tax the PSU too much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16856167036
The system shouldn't be drawing too much power with:
AMD Athlon LE-1640 CPU 2.6 GHZ Single Core 45 Watts
WD 250 GB HD
Samsung IDE DVD Drive
2 each 92mm Fans
Any insight? Does Nvidia offer something better for anything under $40.00 that doesn't required a power lead?
Thanks for any & all insight!
WD 250 GB HD
2 each 92mm Fans
