Hey guys, I don't hang out much around these parts anymore, I haven't used a desktop in years now. Been using this Gateway P-6831FX for close to 3 years now as my main computer.
Here's the thing, I have some hard drives, and a half-working old Gateway desktop which contains in it a Q6600. If I were to make the least amount of upgrades necessary to get a functioning computer, what would you suggest?
I'm thinking about a cheap motherboard (the one I currently have I believe has given problems. Fan would rev up on the CPU for a few seconds, and then the computer would shut off, despite temperatures being normal). So a cheap motherboard, but then some DDR3 ram that could be transferred to a new rig in the future, since DDR3 is cheap now.
This is what I've found at Newegg. Is it reasonable? Will it be fine for 1680x1050? I think it looks like a pretty sweet upgrade for ~$350. This shopping cart is from Newegg
Also, is that Tuniq Tower still a decent heatsink?
HIS H685FN1GD Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16
$15.00 Mail-in Rebate Card
$159.99
CORSAIR Builder Series CX430 V2 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
$44.99
Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3X1K2/8GX
$48.99
BIOSTAR P43D3 LGA 775 Intel P43 ATX Intel Motherboard
$59.99
Tuniq Tower 120 Universal CPU Cooler 120mm LED Cooling Fan and Fan Controller/Heatsink
$26.99
Tuniq CR-BP1156-T120EX LGA1156 i5/i7/i3 Backplate Set
$4.99
Subtotal: $345.94
Thanks for any comments/suggestions!
$159.99
$44.99
$48.99
$59.99
$26.99
$4.99
Subtotal: $345.94
