Cheap HTPC built
Vithar
Can anyone suggest some parts for a cheap HTPC
Watching movies with netfilx and checking email mostly
lets keep it under $500 after shipping and tax
Southern California, near a Microcenter
MOBO w/HDMI, CPU, HDD, PSU, RAM, CASE, DVD DRIVE, Aftermarket CPU Cooler, and if budget allows SSD and Dedicated Graphics
6) Will you be overclocking?
no
a 50in 1080P Sony Bravia TV
two or so weeks from now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
HDMI
7 Home Premium 64
11) Any other considerations towards parts? (This should be a thing, imo)
Case has to be small form factor like the cooler master elite 360
$66 - Intel Pentium G630 CPU
$75 - Gigabyte GA-B75M-D3H Intel B75 mATX Motherboard
$18 - G.Skill F3-10666CL9S-2GBNT 4GB DDR3 1333 RAM
$90 - Samsung 830 128GB SSD
$70 - Western Digital WD5000AAKX 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$18 - Samsung DVD Burner
$45 - Corsair 430CX V2 430W PSU
$79 - Silverstone PS07B mATX Case
Total: $461 plus tax
Thx, btw I was thinking of an FX6100 and one of those free mobos you get at Microcenter, does that sound good or is that just a waste?
A waste IMO since none of the AMD mobos with onboard video have USB 3.0. Not to mention that in the single threaded use you've mentioned so far, the Intel would outperform that AMD. Not to mention the increased power and heat.
So no AMD at all, not even the phenom 965? I always thought those were a bargain.
The AMD Phenoms don't quality for the $40 off deal. Only the FX CPUs qualify for that deal. With that said, whether or not to go the AMD route is largely dependent on what you will be doing with the PC. If you're doing a ton of video/3D/audio encoding/rendering or Photoshop work, the AMD Phenom II X4 and AMD FX CPUs will perform better than similarly priced Intels in that kind of usage but with a dramatic increase in heat and power usage. However, that advantage is pretty much lost once you go above the $140 mark since the $180 Core i5 2310 will generally outperform the AMD FX CPUs in that kind of usage.
If you're gaming, hands down, it's Intel all the way as even Pentium G8xx series CPUs will outperform the FX-8150 in some games. For Netflix and web browsing, any dual-core CPU will perform just fine for that kind. In those cases, you have to determine which platform to go for via other factors as features (i.e USB 3.0), power usage, heat generation, and price
Actually the phenoms do qualify that's why I asked, its at the bottom of the page, you get a free GA-78LMT-S2P which could potentially mean $50 saved. Besides that silverstone case looks like it can store a hyper 212.
Ahh I was looking at the catalog, not the site. In any case, that Gigabyte isn't a good choice since it doesn't have the one thing you specified under question 9: a HDMI port. Not to mention that it's the old 760G chipset which means that it'll perform even slower than AMD's 8 and 9 series chipsets. In addition, the onboard video didn't have the capability to offload the decoding of flash or HD content. As such, all of the decoding would be done on the CPU, not the GPU like it would with newer video cards and onboard videos. That further impacts the performance of the system. Also, that mobo is actually $10, not free, as you still have to deal with a rebate that may or may not go through.
Dang so that's where they get u, I mean I was thinking I use the saving to purchase a cheap GPU, but with the motherboard actually being that outdated I'd just be wasting money wouldn't I.
IMO yes.
