Siriusmuzik
- Oct 7, 2007
Hi guys,
I will be reusing any part that is not mentioned here in the buy list. I have my own windows 7 key, monitor, keyboard, mouse, harddrive.
I am looking for a gaming build. I game at 1920x1080 resolution.
Here is the part list I put together from Microcenter. I'm decently flexible with my budget.
1. Thermaltake V4 Black Edition VM30001W2Z ATX Mid Tower $39.99 (29.99 AR)
2. LG 22x DVD±RW Burner with Dual Layer Support $17.99
3. MSI H61M-P23 (B3) LGA 1155 H61 mATX - $14.99
3. Intel i3 2100 Processor $99.99
4. Corsair CMX4GX3M1A1333C 4GB DDR3-1333 $22.99 ($17.99 AR)
5. Cooler Master eXtreme Power Plus 500 Watt $39.99
Total $254.15 not including rebate
I need suggestion for a videocard I can buy at microcenter!
I was also thinking of doing a AMD 1055T build, since it's only $30 more.
What do you guys think? Intel i3 2100 setup or AMD 1055T?
Thanks!
GAMING, CSS, SC2, and BF3
Flexible
USA
CPU/MOBO/RAM/PSU/VIDEO CARD/DVD BURNER
MONITOR (DELL U2311H), keyboard, mouse, speakers, windows 7.
6) Will you be overclocking?
Budget doesn't allow, otherwise YES.
23" 1920 x 1080
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
USB 3.0 would be nice so as SATA 6 Gb/s
Yes, Windows 7 64 bit
Thanks!
Flexible
USA
23" 1920 x 1080
ASAP
