Gaming
Around $700
3) Where do you live?
Chicago, IL
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
PC parts, not a monitor.
6) Will you be overclocking?
Probably.
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Raid and either crossfire or SLI
10) Do you already have a legit and reusable/transferable OS key/license?
yes
Here's what I have so far:
Raidmax Sagitta 2 $55
AMD 9950 $105
700W OCZ $70
DVD Drive $26
2X 1tb Seagate HD $170
Current subtotal: $426
What I have left to decide is the motherboard, graphic card (s) and RAM. I was sort of stuck deciding between SLI and Crossfire. I was thinking of either getting one GTX 260 off of ebay for around $130 with cashback and then later eventually picking up another GTX 260, or buying two radeon 4830 for about $140 total after cashback. I'm pretty new to building PC's and don't have the slightest idea as to which setup would be better. I also would like a decent motherboard that would be good for overclocking. Any help or alterations to the build would be appreciated, thanks!
Gaming
Around $700
Chicago, IL
Probably.
Now
yes
AMD 9950 $105
700W OCZ $70
DVD Drive $26
