Cheap gaming build
Rustyj
How does this build look trying to stay under 450 have a 19" lcd so resolution will be at 1280 X 1024. coming from an Barton 2.5 and a ati 960 pro so this should be a pretty good step up I think. would like a little beter cpu but trying to keep the 3850
BIOSTAR NF520-A2 AM2 NVIDIA nForce 520 MCP ATX AMD Motherboard $48.99
http://www.newegg.com/product/product.asp?item=N82E16813138077
HIS Hightech H385F256NP Radeon HD 3850 256MB 256-bit GDDR3 $169.99
http://www.newegg.com/product/product.asp?item=N82E16814161211
COOLER MASTER eXtreme Power Plus RS-460-PMSR-A3 ATX12V V2.3 460W Power Supply $39.99
http://www.newegg.com/product/product.asp?item=N82E16817171028
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz 2 x 512KB $57.99
http://www.newegg.com/product/product.asp?item=N82E16819103774
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit $42.99
http://www.newegg.com/product/product.asp?item=N82E16820211066
Seagate Barracuda 7200.10 ST380815AS 80GB $43.99
http://www.newegg.com/product/product.asp?item=N82E16822148231
total is $403.94 without shipping
The os will be Vista wich I have on the shelf here unused now.
case,dvd-burner etc will be from my exixsting build and later replaced as needed
For Enginurd's and lazy people's sake, could you please list out all the prices and the total costs of the PC?
You're going to need an OS, I don't get why every build pretty much leaves this out (everyone is a pirate or has a retail license?).
Wouldn't trust that power supply. Fsp makes great inexpensive units.
For $8 more you can get a 160gb hard drive which is double what you got now.
QFT. Please list all your parts so we don't have to click on half a dozen links. Thanks.
Some people need a new OS license, and others don't. Many Linux distros are free. Many schools have free Windows licenses for their students. Some people have retail Windows licenses. What's so hard to understand? If you they don't list it, and you think they need it, ask them.
Some FSP units I wouldn't trust, either... especially any Epsilon based units, nor their budget AX* line.
Since you mention a HDD... Frys.com has the Seagate 320GB for $65, btw.
