Let me start by saying this will be my first computer build, and until about 3 days ago i knew nothing about building a computer and how overwhelming it is. That being said im really worried about compatiabilty issues. the insperation for this build is the pending release of diablo 3( which will probably make me a single man again) and i have been looking at components based on the recomended specs listed for this game. i would like this machine to last a year or two, and im not opposed to uppgrading down the line. my budget is around 500 bucks, just because i would like to build it by the release of the game, may 15. if in 6months i have to uppgrade something that shouldnt be a problem, ill have lots of money when im single.
ive decied to go the amd route.
im going to need every thing.
case, psu, cpu, mobo, memory, gpu, hdd,
i plan on using an old mouse and keyboard until i can afford new ones. and i plan on using my tv as the monitor for now. i couldnt find the resolution but its a vizio 47" 1080p 120 hz
i will list some of the things i was thinking of buying, im worried about some minor overlooked issue such as a 20pin connector for my psu and the board uses a 24 pin. im also a lttile confused about the pciE version. the mobos that i have looked at dont mention the the version and im assuming that its uppgraded to the newest upon instal. like i said im VERY new to this.
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1963432&sku=G452-2612
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=6620917&sku=A79-0450
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1499293&CatId=7005
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=606321&CatId=1483
as far as the memory and case im not too picky. my require ments for a case is that it has built in fans and is around 50 bucks. also do the fans plug into the mobo or the psu
i plan on buying 8g of memory but havnt looked at too much of that yet. im aware of the differnt types (1333 2000... and will buy what every my mobo accepts.
being very new to this i dont plan on doing any OC or using mulitiple gpu at first but may in the future.
i know there are things im forgetting and would love to hear any imput from the pros on this.
thanks in advance
im in orlando fl if that helps.
thanks in advance
