- Oct 29, 2000
Hey all,
I'm building a low cost HTPC and trying to use as many parts as possible from my old parts closet.
Long term I want to put a big quiet cooler on it, so the noise doesn't interfere with watching movies.
Specs:
- New FM2+ mini-ITX board.
- New Silverstone SG06 case
- Used Richland based A4-4000 from ebay
- 8GB of RAM I had kicking around
- 128GB OCZ Agility2 SSD from my old HTPC
So the question is this. I have two older copper AMD boxed coolers from my Phenom II 1090T and FX-8120 Bulldozer in my server, neither of which I am using. They were really inadequate for those 125W TDP CPU's IMHO, but I think they might do a decent job on a 65W chip, and certainly should be better than the wimpy little aluminum thing that comes with the A4-4000
What do you guys think?
1.) Will they fit? (this will be my first FM2/FM2+ board, are the brackets and dimensions the same as AM3/AM3+?)
2.) If I have one of these set up on auto fan control off of the motherboard header, whill it be quiet enough at stock speeds, or will the 80mm fan wind up and make lots of noise, like it did on the 1090T and 8120?
Much obliged,
Matt
Specs:
Much obliged,
Matt
