Cheap case I/O panel hell
ashmedai
Got this cheap piece of junk case that I'm trying to stick a motherboard in for a friend. I/O bracket won't stay put for the life of me. Any recommendations on how to fix the cheap POS other than resorting to a little sledgehammer action? (after seeing IceWind's thread earlier, it's very tempting...)
And yes, I tried pliers.
In my experience the I/O plate hasn't stayed put by itself; it has been necessary to seat the motherboard in the case which holds it in place. Or have you done this?
Yeah it pops out on one end all crooked-like. Too bad I don't have access to a MIG welder anymore.
Not to sound all low tech, or anything....but have you considered two-sided tape? super glue?? I mean honestly, it doesn't have to look primo, since it's on the back of the case, right? :)
Nothing like coming back later when you're alot less frustrated...okay fine so I came back later with a hammer and some pliers, and after getting really low-tech on its ass, finally got the thing to stay in. No blood even, for once. :D
Upgrade complete!
it's not gonna hurt anything if you leave it out. maybe some extra dust will get in there, but it won't be anyhting bad. I've had to leave out an I/O shield plate and there was nothing wrong with it.
