Changing Timings and setting Voltages
zpanacek
In previous threads I have written about BIOS help.. Now I am asking for some real help!
I understand the Cell Menu is where I change these things..... But the Bios does not allow me to change the Voltages of the memory NB or CPU why the hell not?:mad:
I have been at this for a day now.. I have tried everything under the sun and nothing seems to enable me to change these voltages. and another thing what should the memory ration be?? Auto or 1:1 1:1.33 1:2???
I am sorry to ask so many times but no one seems to be able to help me.
Thanx for letting me rant.:)
Just so you know you are not being ignored, I have looked and cannot find out why those bios settings will not change. All I can suggest is a query to MSI tech support or if there is a MSI forum perhaps a post there as it is not a popular board here apparently.
The only thing I can think of is with most bios if there is an "Auto" setting somewhere it typically prevents you from going in and changing detailed options until you put it on "manual" but I cannot find it on the limited screen shots of your bios I have looked at.
You use the memory ratios to run your ram at speeds higher than 2x the FSB.
1:1 is the standard setting where memory runs at 2x the FSB.
Your cpu always runs at a speed equal to the FSB x the cpu mulitplier
But lets say your FSB was set to 333MHz because you have a 1066 Buss CPU but your memory is PC6400 (800MHz) memory. At the default 1:1 your memory would only be running at 2 x 333 = 667MHz and would be underclocked. If you used a memory mulitplier, in this case 1.2 would be ideal, your memory would run at 2 x 333 x 1.2 = 800MHz (minor math rounding of numbers applied).
