Changing the fan on the Antec 920
waseem
What is the best fans 120mm to change from the stock that camr with the antec 920 ?
I'm doing OC for the i7 930 with the asus p6t - se
I'm stable at 4.18 GHZ at 1.365 v
temps at load 68c - 72 c
thanx :)
Corsair SP120. The airflow is significantly better than any other 120mm fan and it's designed for high static pressure, such as radiators like your 920.
Follow the link and look at the following two articles: http://hardforum.com/showthread.php?t=1725851
120mm Fan Roundup: 1350 RPM or Lower Rotation Speed
XbitLabs, November 2, 2012
120mm Fan Roundup: 1350 RPM and Higher Rotation Speeds
XbitLabs, December 13, 2012
