Flogger23m
- Jun 19, 2009
I am going to be upgrading to a new motherboard eventually. I am wondering if I can swap out the motherboard/CPU/RAM, then boot back into Windows 7 64bit Pro and use it as it was without having to wipe my Windows install. From what I understand this can be done in Win 7, though it depends on what motherboard you are coming from and going to.
My current motherboard is a rather old ASUS M3N78 Pro:
http://www.asus.com/Motherboards/M3N78_PRO/
I will be moving to something which can run the Intel i5/i7 4***. I am not sure which specific board I will use yet, though I will probably buy another ASUS board if that makes a difference.
I am wondering if anyone has done this before with success on Windows 7? If so, from which motherboard did you upgrade from and to? And what extra steps did you have to take if necessary?
