changing dvd regions
ColdCrow
I have no idea but my dvd region is set to 8....which is,
"Region 8: Special international venues (airplanes, cruise ships, etc.)"
I don't know why it is set to that. I never messed with it before, and purchased the dvd burner in the U.S off of newegg.com.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151154
I have to have it to 1 which is.
"Region 1: U.S., Canada, U.S. Territories"
How do I change it? And anyone know why it was on 8?
Its also region protected so the programs I have tried wont work!
I just want to change the region to 1, I have enough attempts and when I try says
"Unable to update region settings. Please make sure the drive contains a region 1 media and you have administration privilege."
I am admin, and I have a region 1 dvd in there.
yes, its the reason I'm in this mess.
oh and i was able to change it to 2 with out getting the message but when I try to change it to 1 it wont let me.
I hate this drive i'm going out now to buy a new one.
Try contacting Samsung or Newegg and see if they can help.
Though for some reason, the region settings on your DVD burner might have been changed 5 times. After the 5th change, you're locked into that 5th region change forever. Just a possibility.
In the past, could this DVD drive play region 1 DVDs just fine? Also, what software were you using to watch/play DVDs? What DVD is this?
I don't think I ever have tried to play a DVD movie on it before. And I have never changed the Region before. I am trying to use windows media player in vista.
