Changed multiplyer setting P5N-E and e6600, not sure it worked
Jared701
Ok, my motherboard loading screen shows my multiplyer was changed showing it's at 3.2 gig (8x 400fsb) Orthos, windows and core temp all show I'm running at 3.6gig while cpuz reports 3.2. I believe I am running at 3.2, but how do I know which program is correct?
If you did not disable EIST and C1E they probally all are correct as you mulitplier is being adusted "on the fly " depending on load.
o_O I did not even know the multi could be switched on the fly... I'll have to check the bios settings and see if I can find that
