Change graphic card
Radek
Hallo, could you advice which better graphic card could i use in my computer? I would like to try mine.
The computer content now:
AMD Ryzen 5 1600X Six-Core Processor
RAM 16MBytes - 1197.6 MHz
Motherboard - AMD Ryzen SOC PRIME B350-PLUS (AM4)
Graphics - NVidia - GeForce GTX 1060 6GB
Storage - WDC WD7500AZEX-00RKKA0
Optical drives - ASUS DRW-24B5ST
Operating system: Windows 10 Home 64-bit
thank you radek
RTX 3080 is probably the best one for value. I have one I would sell but since you are new you would have to pay via Western Union Money Transfer.
yes, as long as your case is large enough and your PSU is at least 500 watts for mining. If you try to game with it you will want a 650 at least.
