Chaintech ZNF3-150 Problemos
laws_69
First off, this board is horrible. Manual is terribly written. There is virtually no support on the chaintech website or on Nvidias. Board will work with my Corsair XMS3200 c2 v1.2 ram but not an old stick of the same that is v1.1 (which upset me immensely). Anyways......
I cannot get the SATA drive recognized. There is nothing for SATA or SCSI or OnBoard Controller in the BIOS. There is no Raid Bios for the SATA chipset (Silicon Imagine 3114). I've flashed the chaintech to the latest bios to no avail. Windows 2000 install doesn't recognize the drive, even when I pop in the floppy to install the SIL drivers per usual. I'm going to attempt using the Seagate Disk Utility after work to see if I can at least find the drive and perhaps format it.
Has anyone else delved into this POS board? Any ideas on getting the SATA to work. All cables are new (not nicked or anything), power adapter is setup (the PSU is sata ready anyways), everything is hooked up correctly (i get post, drive is warm and spins). Please help me get this sexy AMD64 system rolling.
You gotta be kidding? Nobody has any idea what could be wrong? I tried different cables, different ports, unhooking all other devices...NOTHING works. I'm thinking there has to be a jumper on the board, but it isn't in the manual.
shit, i have no idea...and i just bought that board (haven't found the time to put the system together yet though :() is it really that bad? grr, i wish i could help you...jw, what SATA HDD you using?
Seagate 80gb SATA
I tried it all. The only thing I can think of is all versions of the Chaintech BIOS do not control the SIL 3114 controller. I went out and bought an ATA drive and Win2k is operational....hopefully I can get the SATA working sometime in the future and/or sell the damn drive.
I think I've figured out what it is..this "Broadcom Lan" is taking up like 20 PCI devices. It clogs the boot screen and also clogs the device settings in windows. It MUST be keeping the SATA out of the mix. However....there is no jumper for this broadcom crap, nor a bios setting to remove it. This is just the absolute worst board I've ever seen.
Called Chaintech tech support. Apparently the board is bad and I need to RMA it. All Bios revisions are supposed to automatically pickup the SATA controller, this one doesn't. Somehow it must have been damaged. :( CLOSE THREAD
