Chaintech, crap/gold
Silent Assasin
Ok, so I'm plannin on building my first whole computer soon. I've done a lot of modding and add-ons to the first computer i bought 4 years ago, i'm only 16..... But ok well it's about time to put out some more money for a completely new rig, i've already maxed out everything capable on my P4 motherboard.
New rig specs-
Ram: 2 sticks of Corsair 184 Pin 512MB DDR PC-3200 - OEM (http://www.newegg.com/app/viewProductDesc.asp?description=20-145-026&depa=0&manufactory=BROWSE)
Procesor: AMD Athlon 64 3200+, 512k L2 Cache (http://www.newegg.com/app/viewProductDesc.asp?description=19-103-483&depa=0&manufactory=BROWSE)
Vid Card: Saphire ATI Radeon 9800Pro 256mb, 256bit color (from local store)
Hard drive: 2 80GB Western Digital Ultra ATA's (also VERY cheap from local store)
Case: RAIDMAX Black 10-bay Case with 420W Power Supply, Model "ATX-868WBP" (http://www.newegg.com/app/viewProductDesc.asp?description=11-156-135&depa=0&manufactory=BROWSE
motherboard: OK now this is where i have the question about. I've been lookin around at prices. I found this mobo for only 79 bucks, and the next price was like 200 bucks..... I'd prefer an ASUS board but if i can get away with a descent board for cheap like that, i'd take it. I'm really building on a buget here. (http://www.newegg.com/app/viewProductDesc.asp?description=13-152-043&depa=0&manufactory=BROWSE) Also another question i have about this board is if it will fit in my new case. The specs on the case says it can handle mobos up to 12" x 10.5". On the chaintech, there is know dimensions, so i went straight to the chaintech webpage, but the problem there is that the dimensions are in metric. So i did the conversion and it comes out to be like 12.45" x 8.5" or sumthin like that..... (http://www.chaintechusa.com/tw/eng/product_spec.asp?MPSNo=13&PISNo=276)
Crap i'm retarded, i guess i missed the part that said it was onboard Serial ATA. Does that mean i can't use my Ultra ATA drives? I know the motherboard is like the most important thing and prolly shouldn't be skimped on, but i want a good gaming machine that is about 800/900 bucks. Right now with all that crap plus a sony dvd player and a sony 52x cd burner i'm at about $840. So if i had to i don't wanna go too much higher with the mobo.
I've already got a good sound system, monitor, mouse, keyboard, headset, joystick ext.
Just a couple of notes:
socket 939 90nm 3200's are out if you want to go that way. It doesnt really that much more of a performance gain but then you do have "socket of the future"
As far as socket 754 goes (which is what you have listed), there really is no question, DFI Lanparty UT N3 250Gb. $107 at newegg if you can find in stock (out usually) or $130 from gameve. Dont know if others carry it yet.
EDIT: All mobos have Ultra ATA in ADDITION to SATA. (most mobos over 100$ also offer SATA RAID.)
I would go with a soket 939 processor over socket 754. The lower end 939 shows in stock over at Monarch.AMD 3000+ at Monarch.
Pair that with an MSI K8T NEO2 from Newegg.
And you've got a pretty good basis for an upgrade that is somewhat future proof, socket 939 should be around for awhile.
As far your Ultra ATA hard drives are concerned, they are IDE drives so any of the above motherboards will be fine.
socket 939 will be around for a bit BUT by time he will want to change processor there will be reasons to change the motherboard as well. ALL my upgrades seem to end up that way. I can think of a couple if not more reasons right off the top of my head, PCI-E, Nforce4, the list goes on and on. Paying more for upgradability is folly since in most cases unless you plan on upgrading SOON as in within 6 monthes. Otherwise expect to change the motherboard along with the processor.
Yeah, I'd tend to agree, and the s754 boards seem a bit more mature at this point than the 939 ones... More people with 'em, more results out there, more BIOS updates, etc.
Ok wel i have looked into the 939 boards, but like i've said, i'm building on a budget. Also as elch said, by the time I wanna upgrade again won't be for another year or two. I kind of want to stay with the 754. It just seems that it's more stable to me.
So if anyone can find great mobos for cheap that will fit those specs, it would be great appreciated.
The chaintech dimensions would be 12.007874"x8.6614173" so I'm guessing it would fit. The decimal value on the 12 would be negligable in this case, so you're fine. It's been a pretty decent board for me, but I have yet to really try and overclock it because I've been extreamly busy with classes this semester...that and my video card still needs upgrading so there is no point really.
I do hear really good things about that DFI Lanparty board, so that's always a good choice as well.
If you dont want to get the DFI, Chaintech really is a good choice. IMO, DFI is better than all others at that particular price point of around $130 and above. But Chaintech is much less than $100 and offers good OC and functionality.
