- Aug 15, 2005
ExcellentI changed the profile from standard to manual for all the CHA_FAN headers. Then, I used a curve similar to the one you suggested which is shown in the pictures below. The maximum value I can choose for the upper temperature is 75. I can hear the fans speed up now at times, so there are working. I misunderstood, I didn't realize you can still have a curve when changing the profile to manual. For some reason, I thought the fans would run at a constant speed when changing the profile to manual.
I also tried HWINFO. I didn't realize my CPU temp is only in the 40's when playing games. I thought it would be much higher. Unless the curve I decided to use is really not recommended, I should be all set. Thank you!
