CDW Outlet Finds
HP Enterprise 1TB 3.5" sata drive for only $21:
https://www.cdw.com/product/hp-1tb-6g-sata-7.2k-3.5in-nhp-ety-hd/5480409?pfm=srh
https://www.cdw.com/product/hp-1tb-6g-sata-7.2k-3.5in-nhp-ety-hd/5480408?pfm=srh
HP 24-port poe+ unmanged gigabit switch for $55 that's normally $120+:
https://www.cdw.com/product/hp-1420-24g-switch-bstk/5518736?pfm=srh
HP EliteBook 800 series laptop battery for $58 that's normally $150+. What's interesting about the genuine battery is that it comes with a 3yr warranty:
https://www.cdw.com/product/hp-sb03xl-nb-primary-battery-bstk/5524322?pfm=srh
They also have 2 more of these that are currently sitting at $75:
https://www.cdw.com/product/hp-sb03xl-nb-primary-battery-bstk/5512062?pfm=srh
https://www.cdw.com/product/hp-sb03xl-nb-primary-battery-bstk/5512067?pfm=srh
HP Ryzen 7 laptop for $802 that's $1200+ anywhere else:
https://www.cdw.com/product/hp-sb-755-g5-r7-2700u-512-16-w10p-b/5520415?pfm=srh
HP T520 36in ink jet printer for $848. This is a inkjet update to the old plotters that printed construction plans and all sorts of large format stuff. This thing usually goes for $2500 almost anywhere you look:
https://www.cdw.com/product/hp-designjet-t520-36in-36-printer/5511866?pfm=srh
HP i5-8250 laptop for $886 that's $1400+ anywhere else (B&H actually has it for almost $1500):
https://www.cdw.com/product/hp-sb-840-g5-i5-8250u-256-8-w10p-bs/5522150?pfm=srh
HP i5-7200 laptop for $1024 that's usually $1600+:
https://www.cdw.com/product/hp-sb-x360-g2-i5-7200-256gb-8gb-w10p/5526597?pfm=srh
And a similar i5-7300 for $1032 that's also usually $1600+:
https://www.cdw.com/product/hp-sb-x360-1030-i5-7300u-256-8-w10p/5522564?pfm=srh
And another one for $1040 which means that $1032 price is the bottom:
https://www.cdw.com/product/hp-sb-x360-1030-i5-7300u-256-8-w10p/5521491?pfm=srh
i5-8250 laptop for $1176 that's normally $1500+:
https://www.cdw.com/product/hp-sb-x360-1030-g3-i5-8250u-256-w10p/5538779?pfm=srh
i7 convertible notebook for $1616 that's normally $2050+:
https://www.cdw.com/product/hp-sb-x360-1030-g3-i7-8650u-512-w10p/5536863?pfm=srh
2x xeon silver workstation for $1774 when the cheapest you can find it is $2500 at B&H:
https://www.cdw.com/product/hp-sb-z6-g4-2x4108-256-32-w10p-bstk/5523110?pfm=srh
Xeon workstaion for $1980 that's $2400+ anywhere else you look:
https://www.cdw.com/product/hp-sb-z4-g4-2133-1-16-w10p-bstk/5540271?pfm=srh
Xeon silver workstaion for $2480 that's almost $3200+ everywhere else:
https://www.cdw.com/product/hp-sb-z8-g4-4116-512-16-w10p-bstk/5536810?pfm=srh
https://www.cdw.com/product/hp-sb-z8-g4-4116-512-16-w10p-bstk/5539613?pfm=srh
There's one more currently sitting at $3100 that will come down to 2480 for sure:
https://www.cdw.com/product/hp-sb-z8-g4-4116-512-16-w10p-bstk/5536110?pfm=srh
Many thanks!
Welcome! And be sure to watch the interface type as many are sas vs sata. And they do mess this up sometimes (hence the deal), so be sure to search the model number to confirm you've got what you want before pulling the trigger. (y)
I noticed that, just have to keep a keen eye when combing through the deals.
Yes, I forgot to mention this!
On the positive side, you can get an sas controller and enter the world of enterprise grade sas drives on the cheap. I've actually gotten 2TB 7200 sas drives for <$50 before. :eek:
nice.
cpu deals/? How do I search for CPU
Good question. I tried the following for Intel and came up with just one:
https://www.cdw.com/search/?key=int...e=all&sr=1&maxrecords=72&sortby=priceasc&ln=2
And then tried these two for Amd:
https://www.cdw.com/search/?key=amd...sr=1&maxrecords=72&sortby=priceasc&pcurrent=1
https://www.cdw.com/search/?key=ryz...sr=1&maxrecords=72&sortby=priceasc&pcurrent=1
You typically don't want to try to filter by category since if something was put in the wrong category, you'll miss it. And in cases like the original Intel list before I added a keyword, it will probably be worth going through the entire list as I'm sure there will be another one or two in there listed as some sort of server upgrade part number that will have a usable processor in it. (y)
This isn't 4tb, but it is a 3TB enterprise drive for about 50% off of anywhere else.
Seagate Exos 3TB $72
Oops! I forgot about the 3TB drives. Search links for 3tb and 5tb drives:
https://www.cdw.com/search/?key=3tb...sr=1&maxrecords=72&sortby=priceasc&pcurrent=1
https://www.cdw.com/search/?key=5tb...sr=1&maxrecords=72&sortby=priceasc&pcurrent=1
And the Exos is Segate's premium product, so this is an enterprise class sata drive with a 5yr warranty and 2M MTBF. Definitely no best buy model. (y)
Guys, the 3TB Exos drive I linked is now $57.
Make sure to check back on some of these if the price is still too rich for you. Those 22" Dell monitors are now $45 a pop, that's a steal you can get 2 with shipping and tax for less than the cost of 1 new.
Several other items listed in the last week or so have dropped again.
Great finds! And don't forget to look at the more expensive ones like this RS3618XS for $1922 that's going for $2600 at B&H:
https://www.cdw.com/product/synology-rs3618xs-12bay-nas-rs-bstk/5551634?pfm=srh
Check out all the Synology here:
https://www.cdw.com/search/?key=synology&outlet=1&searchscope=all&sr=1&SortBy=PriceAsc
Yep! That's the beauty of the outlet--you can just watch an item that's not at the price you want. But keep in mind that if it gets lower than the threshold for liquidation, it will be removed from the outlet and you've missed it. :(
its like quicksand, but for prices
I just went through a bunch of the link I posted previously and a lot of the stuff is gone. :eek: Did you guys buy that much?!? :confused:
Decided to bite on one of the 22" monitors. $63.02 including shipping & tax. I was originally going to order two, but there's no quantity discount on the shipping and I really only have one obscure use for one extra display of this size anyway.
Apple Ipad Pro 10.5 smart keyboard for $49 that's the same price for used ones on ebay and waaaay lower than the $120+ that these usually go for new:
https://www.cdw.com/product/apple-ipad-pro-10.5-smart-keyboard/5499038?pfm=srh
And this is probably the lowest price it's going to hit as I found two more for $60. These will also drop to $49 if you want to wait:
https://www.cdw.com/product/apple-ipad-pro-10.5-smart-keyboard/5510190?pfm=srh
https://www.cdw.com/product/apple-ipad-pro-10.5-smart-keyboard/5514880?pfm=srh
Another one sitting at $94 at the moment:
https://www.cdw.com/product/apple-ipad-pro-10.5-smart-keyboard/5536234?pfm=srh
Pulled the trigger on a UPS. (Pay close attention to input voltage & plug type). Thanks SamirD !! Wouldn't have known such good deals could be found w/o your thread.
Awesome! Be sure to fully inspect it when it arrives because generally they don't re-box them and ship them, and if they were shipped before the factory packing may not be enough to get them to you safe. I've still got two return cases open on two units that were doa due to shipping damage.
But there's some killer deals for sure--and definitely check the specs on what you're buying using the part number as there are a lot of 230v ones in there. (y) I picked up 10+ of these for a little over $70 shipped each just a few weeks back:
https://www.cdw.com/product/cyberpower-1500va-ups-w-avr-lcd/5535692?pfm=srh
And these I just had to post as it's only $295 as opposed to the $900+ that it usually is: :eek:
https://www.cdw.com/product/liebert-gxt4-1.5va-ups-rck-twr-120v/5501919?pfm=srh
https://www.cdw.com/product/liebert-gxt4-1.5va-ups-rck-twr-120v/5493086?pfm=srh
Oh and this one for $308 vs $1100+:
https://www.cdw.com/product/tripp-3000va-ups-smart-online-2u-rm/5485711?pfm=srh
This was I think the exact unit I got that arrived with the faceplate busted off, but at $94 vs the normal $300+, it's a great deal if you can pick it up vs ship. You can ship it, but imo chances are it won't make it in good shape:
https://www.cdw.com/product/cyberpower-smart-app-lcd-2200va-bst/5495391?pfm=srh
My screen showed up today (one of the P2219H models from the previous page.) Aside from the exterior packaging being a bit beat up, and CDW tape over the stock clear tape that had been broken, this seems brand new. All cables included (power, usb, displayport) and it works perfectly. Screen is flawless, parts are undamaged. That was $63 well spent.
And this is why I keep buying stuff from the outlet vs brand new. (y) Glad to see someone else enjoying the savings as much as I do. :)
$63 plus $18 shipping so almost $80 which is what the ost new on amazon. i almost jumped on that, that model was over $100 but, some the $80-90 units on amazon don't seem too bad unless that thing has some real image quality.
It was $63 INCLUDING shipping. Base price $45. See below:
I'm now very dubious about the goods on Amazon as the marketplace has become even more ripe with fakers and shady people trying to unload garbage. The unit from CDW is the real deal as they don't play games since they have large corporate accounts.
I grabbed (1) of the moca 2.0 kits :) These things are awesome...
Oh I forgot to report on my awesome experience with these--was brand new in the box with everything including all the cables, splitters, etc. And got 937 Mbps in testing via iperf. Super stuff for super cheap!
