And even if you still run 32-bit Windows, the infection is in the main exe so uninstalling or upgrading to 5.34 removes the infection...
Both ccleaner and speccy are make by the same company.Well I don't use CCleaner but some things I've downloaded want me to install it (Speccy, etc). But I do not.
When i get a flat tire I buy a new car.you sure about that?...I heard the only way to get rid of the malware is a system restore or a complete Windows reinstall
System restore can't not be the only way, but it can be the fastest way to resolve problems. To do it manually, you will need to identify every single affected files and processes, then restore them. This can take a long time and some files are dynamically generated and you may need to reinstall related programs.you sure about that?...I heard the only way to get rid of the malware is a system restore or a complete Windows reinstall
https://hardforum.com/threads/ccleaner-was-compromised-for-a-month.1944126/#post-1043221839 and glary utilitiesStill use it but been thinking of switching for awhile now. Any recommendations?
Been using since 1.0 days. . . .
Well then I guess we are all infected and there is no way of knowing. Happy computing.It can be almost impossible to prove that all malware has been removed. Malware that has not been signatured will likely not be detected by any AV.
hey Sherlock, I understand supply side attacks. Whether it's NotPetya in the Ukraine or Shadowpad.Come on Holmes. Getting hit with something like this CCleaner malware is is kind of a big deal. Do you understand the resources that went into putting that malware there in the first place?
Is it too hard to be on the safe side here?
Yes I am sure. The malware is contained in the ccleaner.exe file. Get rid of that and you've removed the infection. No external processes were installed by this malware (for once).you sure about that?...I heard the only way to get rid of the malware is a system restore or a complete Windows reinstall
And don't underestimate the fact that if you ran the 32-bit client of CCleaner, you've had a working backdoor on your computer for the last month or so. Information has been gathered and sent off to unknown parties.
Yeah, except if you read the various articles about this infection. The malware gathered and sent information about your computer to a third party and opened a backdoor to your system as well. But there has been no registered secondary infections and the infrastructure meant for this purpose has been seized and taken offline.Those two sentences conflict. The initial infection may be known and limited, but you have no idea what it could have added since then. It was a working backdoor after all.......
No need to drop the program. You don't drop microsoft windows every month when zero day holes get patched or a windows update borks your system.
What I meant with my second sentence is you could do yourself the favour and change your passwords and so on if you've been infected. And do run your favourite malware scanner etc. But so far there has not been any documented secondary infections through this backdoor. So people should relax a little and maybe put down the pitchforks, lighterfluid, tar and feathers and whatnot.
You can also verify with regedit if you've been infected. CCleaner stores it's values in 'HKLM\SOFTWARE\Piriform\CCleaner'. If you've run the infected version, the malware itself stored some values in 'HKLM\SOFTWARE\Piriform\Agomo'. So if you have the second folder in your register, you've been infected. If not, you're in the clear!
