- Dec 24, 2008
yes you are correct, i didn't show all of my commands. I did set to "ip ospf network broadcast". And yes, i'm pretty sure i could use inverse arp, but i'm following a lab and asked to set static maps for everything.
From what i read you can also leave the maps non broadcast, and the use "ip ospf network point-to-multipoint" and then manually specify the ip addresses of the neighbors.
edit: /usr/home, you're doing your ccna pretty soon too right? Does my switchport port security description look accurate?
