CCC Update Problems
xxdmxx
Anyone else get problems with updating CCC?
Every time there is an update the install stops in the middle and says there is a problem writing a file of some sort and have to end up uninstalling CCC, using Driver Sweeper and have to attempt to install a few times before it successfully installs and has CF working properly.
Are you supposed to uninstall and driver sweep every time before updating CCC?
I can't seem to install over the old version as it gives some sort of file writing error during the installation.
I'll get the exact error later. But it's usually just can't write a file don't recall if it's ever the same.
I don't have UAC on.
I installed the 11.10 preview and gave me an error in installation, but looking at the report there was no error reported. After I just tried installing over it by running the setup as administrator and installed successfully.
Update:
Never mind it didn't install properly. Found out when I tried to open CCC couldn't enable Crossfire and Overdrive second card. Had to Uninstall -> Driver Sweep -> Install for it to work properly.
