- Apr 16, 2004
ShePearl said:And according to Catalyst Maker, 4.12 BETA is better than 4.11 especially for Half-Life2.
skritch said:Who/what is Catalyst Maker?
FiZ said:4.11 average fps out of four runs, all settings maxxed:
No AA/AF: 101.52
4X AA/No AF: 86.67
4.12b average fps out of four runs, all settings maxxed:
No AA/AF: 105.98
4X AA/No AF: 94.62
Note: Specs in sig, also in the 4.11's some texture corruption occurred with AA enabled, especially on the bump mapping around the floor area (purple). The 4.12b's did not have this, nor did the 4.10's. Video card at stock speeds.
Conclusion: They kick ass. A very nice boost with AA enabled.
LOL! Oh damn that's sad. CS:S VST. Sorry.fallguy said:Perhaps if we knew what game you tested on...
How about CCC ?FiZ said:CS:S VST 1024x768
No AA/AF: 101.52
4X AA/No AF: 86.67
No AA/AF: 105.98
4X AA/No AF: 94.62
SocketA said:So what about other games? I mean if this is an optimization just for HL2. I don't want to keep reloading drivers to optimize game performance. By the way, right now I play mostly online UT 2004, CoD etc..
ShePearl said:How about CCC ?
Did you install CCC with Catalyst 4.12 Beta ?? I ask because of A.I. option/setting which is only available in CCC.
MrFace said:I tried playing my NFS: Underground 2 demo and it wont show anything but the tail lights![]()
mentorxxx said:this is a problem only of the 4.12 beta right ? using 4.11 it's fine .... or not ?
It allows for general (trilinear, AF) and app-specific optimizations. I believe it is on by default if you don't have the CCC. It has three settings: disabled, standard, and advanced. Standard is considered by many the best overall selection.mentorxxx said:what exactly is the benefit of having the A.I. option ? (i have an x800 pro vivo)
mentorxxx said:after all the problems i heard here and especialy the NFSU 2 bug ,i prefered to go from 4.10 final to 4.11 final and not try the 4.12 beta at all .
There is an AMAZING difference with 4.11 !!!!! i gained +1017 points in 3d mark 2005 !!!!
YES it's not a typing error !!! +1017 3d mark2005 points !!!!!!!!! using 4.11 final version from Ati .
I will not use CCC, but AI can still be enabled (and is by default) through the registry. I had it on the 1st setting (not sure what its called, normal?). I'll try the more aggressive setting and see what happens.ShePearl said:How about CCC ?
