- Jun 6, 2003
Hey guys,
To update my church network I thought I would dive into the scary world of Cisco managed switches...
The one I have - a Cisco 3650 24port managed switch off ebay seems to boot fine, it is that the reset routine called out does not work.
Symptoms:
Power up, the choir of fans starts up and the syst LED blinks fast until all lights light up and then it comes to rest with the SYST and ACTV lights on solid green from the bottom row. and also the STAT light is solid green. when I hold the mode button per the documentation, (3 second duration) the STAT LED turns off and the DUPLX LED turns on,( next one down the top row)
Can any [H]Network techs help a simple end user assistant out?
Symptoms:
