Do you have VC++ 2005 and 2008 redistributables installed?
I'm currently running 10.3.Are you installing from a previous version?
I uninstall my Nvidia and install my new ATI card last night and everything is working fine.
Is hardware acceleration of videos fixed? By that i mean the BSOD that you get in videos using DXVA, or youtube with flashes "hardware acceleration" turned on
Try running the .NET 3.5 redistributable. This was one of the steps XFX detailed in my case and it may have played a part in the driver installing correctly.I'm currently running 10.3. I've tried installing over 10.3 as well as trying to uninstall/driversweep before installing. No luck.
In my experiences, no.I see posting problems here and there about ATI and CCC. Is this a stable software?
at the very least, it causes all your monitors to flicker.
I don't even see my monitor flicker when it jumps. Every transition of the power profile is completely smooth with my 5870. I'm at a lost as to why I don't have this issue when so many others do.
The flicker is caused by the memory clock changing, not the core clock. If your memory clock stays constant, you wont get flickering.
The majority of the people claiming to have problems with ati software are the same people who continue to use the ridiculously antiquated process of driversweeper/safemode installations. I've personally experienced driver issues ONLY when I did this method. Do not use driver sweeper and know a little about maintaining an operating system / computer hardware and you should not experience any Ati/CCC issues.
5870 since January (catalyst 9.12 -> 10.8beta) having had no driver GSOD/BSOD or other weird problems.
Control panel -> add/remove -> uninstall ati catalyst install manager -> reboot -> delete ati folder in appdata local -> install new ati drivers -> reboot.
Some don't even bother with all the steps described above; they simply install over top. This is the way I and many others successfully install graphics drivers without so much as a hint of an issue. In fact, I've often wished I could experience a grey screen or an install quirk just because it'd be interesting.
Thanks. That's the way I use to do it, when someone told me to use Driver Sweeper and go through Safe Mode was best option![]()
I don't even uninstall the old one. Just install right over top. Part of the installation process removes the old drivers. Worked like a charm since my ATI 9700 pro.
Yup this is how I do it and how the ATI driver team recommends you do it.
not true.
ati recommends uninstalling the old drivers first.
http://support.amd.com/us/kbarticles/Pages/737-20870HowtoInstallYourATIProduct.aspx#header3
i do that but before installing new drivers i go into safe mode and run driversweeper followed by a ccleaner registry sweep. been doing it that way for years now, never have issues.
WOW!
This is bad. You guys might want to try out Nvidia if you are not into 3 monitor.
Never had one problem with Ati drivers not one. All my games work perfect. To each his own..
not true.
When is Nvidia going to have 3 output per card? Do they support Displayport?
