I dunno. I just read that you should always use velcro ties for CAT6, and that the ties should be at random intervals or else you get waves building up... Something like that.
Are the bits riding little surfboards?
Don't ask me, that's just what I read somewhere...
EDIT: I found the article:
http://www.expresscomputeronline.com/20031124/technology01.shtml
That article seems like it's written by someone who has never wired anything. Or spends 3 hours running a patch cable between his home router and cable modem to match the manufactures specs.
Easy test I generally use and suggest to non-technical people when running Ethernet in their homes like you are. Plug the cable into two devices that can transmit actual data, i.e two computers, and transfer a large file. Don't make 90 degree bends and don't staple it to anything and run the cable where you actually need it. Re-run test, if you are getting the same results or very close to the same results, you won.
