Hi guys.
I'm going water cooled and looking for a good case.
The criteria are:
- at least 8 expansion slots as I will run 4 double slot cards;
- my board doesn't have on board usb 3.0 header, so pass-through cable would be
preferred;
- enough space for 4 hard drives
- I don't want to spend more than 200, case might be used
I already took into consideration few case, such as 800D, which I like very much, CM HAFX 942, CM Storm Trooper and Thor v2 and Blackhawk, also considered NZXT 810, Antec 1100
Now issues with them - 800D - I wasn't able to find a custom panel for the back (stock one has just 7 expansion slots);
Antec 1100 doesn't look good, it's looks just like a box, not more than that;
I had a chance to work with Rosewill Blackhawk and quality of the materials used was OK
I think NZXT 810 should cost 130 bucks, like Thor 2 and it is too boring for my taste.
What would you guys recommend?
There is no way I would pay 600 or more for Temjin - it's a great case and I can afford it, but seems to be to much for a case.
Any reviews on Xigmatek Elysium?
As of right now I am using a transformer by Antec - Lanboy Air Yellowand it's a bit too tight for everything and it will go up for sale after I get my new case.
Thank you all in advance
The criteria are:
preferred;
