1Wolf
- Jul 10, 2007
I've got an NZXT Switch 810 case and an ASUS P8Z77-V Deluxe motherboard. I'd like to take advantage of the additional Fan Xpert fan controls I've read about for the ASUS mobo...so that the Mobo can spool the fans up and down as it sees fit.
I'm guessing I'll need PWM fans for that (Please correct me if I'm using the wrong terminology)...so I was thinking of replacing the 140mm NZXT fans that came with the case with fans that would work with my Mobo and, overall, be better fans.
Any advice or recommendations would be appreciated.
