Case Dilemma
Carnage311
After upgrading my whole pc recently I got to looking at my case and I noticed that I still had the same case I got over 3 years ago. And while it has been a good case it is just your standard mid-tower case with a side window. It came with a 400W psu which I quickly junked and it only cost me $40. Well I have about $120 extra to spend and I thought well why not get a better case for all my kickass hardware. I've basically narrowed it down to 4 choices: the Aerocool Spiral Galaxies Full Tower Case, the Thermaltake Soprano, the Thermaltake Tsunami, or the Coolermaster Centurion 5. Just let me know what you guys think is the best choice, because all of these cases are awesome in my opinion and I can't seem to choose just one. And of course any other suggestions for a new case are welcome. Or do you think I should just keep my current case and buy a Western Digital 320GB hard drive to go along with my current 120GB hard drive.
Def the Aerocool or the Centurion, based solely on looks. But that's all I can give you. No xp with any of them.
But, you can never have too much storage, too... I'd go with a Maxtor or a Seagate before I got a WD, though.
Ive owned the Aerocool case, its nice but it has some flaws, when you have lots of HDDs teh PSU exaust idea breaks down and dosent work that well. The top of my case became to hot to touch. installing a top fan fixed all of that. But still a design flaw, no efficent HDD Ventilation.
Aerocool Masstige. I've said it before, and I'll say it again. If you intend to WC, this (or the stacker) is the case you want.
Negative Arcy. The case you get is the biggest one you can find.
I'd rather get shot in the head than buy a Western Digital product.....that being said I like the Tsunami.
I would avoid the Psunami, I have had that case for about 6 months and its been a pain. Go for something with a simpler look to it, USB on the front of the case, and for freaking sake no door.
I've worked with the centurian 5, it is a very well built case, and looks very nice. I would go with that out of all the choices.
L1ght said:
What??? No Lian Li choice?? :confused:
Check this out.
http://www.newegg.com/Product/Product.asp?Item=N82E16811112099
Or increase your budget and get a Lian Li PC-V1200. One of the best cases ever made.
Yea what the hell! No lian li's in mind!?! :p
I own a pc-7bw (has a window for like 30 bucks more).. best case I have ever owned.
If I had to choose between the ones you listed, though, I would go with the cent 5.
