Case and PSU option for home server
eagleknight
I am planning a Windows Home Server. I am trying to decide on what case to get. Some searches I did pointed me in the right direction, but have a couple questions. I want a case with at least 4 external 5.25 drives. This way I can use a 4 in 3 hard drive cage and still have one bay left for a DVD burner.
I found a Cooler Master Case I like, but am not sure, which way to go for the PSU. I can purchase it with a 350w or buy the Antec 380w separately(more $). Will the 350w included PSU be sufficient to handle 6 or so hard drives down the road? There are some Antec cases with the 380W included, but they only have 3 external 5.25 drives. If there is some other options that fit the criteria I am open to suggestions.
Case with PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119118
Case without PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119115
Antec PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
Included PSU would probably be fine, hard drives draw about 12w each max. For WHS it makes sense to use the least amount of power and if you can use a mobo with onboard graphics you're usually ahead on the power budget anyway.
No. That included 350W PSU only has 10A on the +12V rail, which is pretty damn weak for six hard drives plus the system itself. I recommend getting the Antec EA380 since it has 27A on the +12V rail, which should be plenty of power for 6 drives or more.
FWIW I ran my HTPC box with 9 hard drives, 6600 video card, 4200+, 2gb ram, two tuner cards, dvd drive, and floppy on a 380w psu for over a year. It was in a media cabinet with so-so ventilation.
I know the max numbers don't always add up, but then rarely is a system like this running everything at max. I will concede that WHS does run the drives more when it balances the pool.
I bought the 330 for my home server. happy with it so far. I'm only up to 4 hard drives so far.
I'm running a Q6600, 4 Hard drives, 2 optical drives, 8GB Ram, GTX 280 on a 500 watter :p Runs great.
